Hello,
I have a 2001 infiniti qx4 and it seams no matter what I try, the driver side high beam will not work. Both drls run fine on each side but when switched to high beam the driver side simply turns off. I have completely replaced my drl module, checked continuity on all the wires I could think of, swapped bulbs and relays and checked all fuses. I am at a complete loss now of what the problem could be. If you have any ideas please let me know as I am trying to sell the vehicle and cannot until this issue is resolved.
If I cant figure it out, is it possible to just run the driver side drl/high beam spliced into the passenger side wires which I know work, or would that not work either?
Any help greatly appreciate
