Infiniti QX4 2002 starter problem
ichendua
Car: Infiniti Qx4 2002
Hello Team,
I am having this starting issue on my Infiniti QX4 2002.
Each time it happens I must change the starter motor to be able to start the car.
When I start I hear a click sound but the car won't crank.
I have change 8 different starter motor for the past 5weeks.
And it does not give me signs before it happens and no matter what I do it will not start until I change to another kick stater.
I would like to know if their is anything that can kill solenoid in QX4
Reason: Revised title
rgk
Car: 02 Pathfinder LE 3.5 auto 4x4
Are you putting the same old solenoid on a new starter? It sounds exactly like a bad solenoid.
If you are not, then check or replace the battery, the cable going to the starter, and the terminals that connect the cable to the battery.
