I have a 1997 Infiniti QX4 which recently started showing CEL with two codes, P0325 and P1447 and have emissions coming up in a month. I am told the code P0325 can be ignored because Knock Sensor has little to do with emissions and that it is the EVAP system that needs to be replaced. I am looking at a EVAP Canister Purge Volume Control that needs to be replaced and I am being told by a store that it is the same as a Canister purge Solenoid. Is that really true? Also, the store tells me that the EVAP Canister Purge Control Valve is nothing but a Vacuum Cut Valve. Is that true? I took the Vacuum Cut Valve to the shop and the guys at the shop had me return it because it was the wrong part. The store insists it is the right part.
This whole EVAP system on the Infiniti is mind-boggling at best. Wish they had made it a little simpler. I am still looking at a massive repair bill
I need some clarifications and I hate having to leave the truck at the shop again and again because the part was not right.
Thanks
