Q45tech wrote:"But maybe since the changes to 94-96 aren't huge "
say what............ about 87% of the components are different! the engine , transmission, driveshaft, the seats, the interior, the dash indicators are flipped, the radio, all the wiring, the doors, the fenders, the entire front, the hood, the front shocks, the steering rack, the AC system, the heat, the exhaust piping length, the cats, etc etc,etc. the transmission mount vibration damper, the internal control modules are multiplexed instead of thousands of wires in Gen 1.
the only parts interchangable are the fuel pump, the diff, the individual suspension arms, the rear subframe, the plenum and throttle body.
Oh no!this pains me, I have to disagree with our Guru:help
But I have a differnt angle on this:
The engine is not a an actual redesign but an improvement for reliablity/emmisions/producability and such which just happend to make it (essentially) non interchangable unless many other things changed as well.The transmission is also essentially the same as before with mostly reliability improvementsAs are all other components (that and increased softness and features)The entire car is not so much a complete redesign as more of a thourough tweak.
The driveshaft of course is fully interchangeable Iand ordering a new one for a 90-93 will result in delievery of the (slightly redesigned) 94-96 part.
As you may remember I currently have a 94 driveshaft in my 91, which was fully interchangeble.
In any case your agruements seem to support the division into 90-93 and 94-96 as seperate generations.Which I agree with.
Fred...
