ceningolmo »
https://forums.nicoclub.com/ceningolmo-u33477.html
Tue Jul 11, 2006 3:25 am
There is not a substitute... Nissan Active Suspension Fluid A is the only approved fluid for the system. And, from what I have read, it is unique...so, don't risk anything else.
Keith Bowers (TExasoil) is the resident expert on the Active system and he gave me a tip that helped. Put a few ounces of MMO (Marvel Mystery Oil) in the resorvoir. This will help recondition the seals in the system and will slow or stop some of your leaks. Mine leaked significantly less after trying this.
BTW - I am not sure where you are getting your fluid, but... Joe (everythinginfiniti.com) is typically the least expensive. However, it is a significant invonvenience to order one can at a time. I contacted my local Infiniti shop and explained the situation...told them I would be needing a can of this stuff occassionally, and that I could get it for $xx.xx from Joe. They told me they would be happy to keep a few cans in stock for me when I needed them. And, they are charging me slightly more than Joe does...but, it works out to be a little cheaper locally because I don't have to worry about shipping.
