Infiniti Q45 Wont Start ign sw fuse keeps blowing
Dicemoney6
Car: 1990 Infiniti Q45 *sold*
2003 Infiniti M45 *Sold*
2012 Infiniti M56
I am new to Nicoclub and I have a 1990 infiniti q45 that wont start, one day i tried to start it early in the morning it was dragging and taking long to kick over then everything just shut off like a fuse blew or something i tried to start again and it will not even attempt to turn over, I cant even listen to the radio if i turn the key nothing will happen no noise no light no nothing I checked in the main fuse box under the hood and my ign sw 30A fuse was blown then i replacement it i tried to start it but it just blew again i dont know whats wrong somebody said it might be the starter but im not sure i searched for it and i cant find out the problem can you please tell what you think the problem is so i can get this fixed thanks
Q451990
Starter failures are very rare on the early Q45s - but I won't rule that out completely. I would also be concerned about a timing chain guide failure, which could cause your engine to lock up.
When you say the fuse blew again, was that after repeated restart attempts - or just turn the switch and "pop"?
Heath
Dicemoney6
2012 Infiniti M56
It was just a turn the switch and pop
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
you obviously have a short somewhere.... I would take the car to a qualified technician familiar with nissan's in general and see what they say... Its possible your starter is bad, albiet like heath said its not terribly common on Q.
Welcome to NICO!!
Q45tech
Pull the starter relay to isolate on which side the short is located.
Dicemoney6
2012 Infiniti M56
which is the starter relay?
Q45tech
The relay described in your FSM..........................pretty difficult to trouble shoot without your own copy of FSM [wiring diagrams etc].
Every Q came stock with a mini FSM in trunk.
Download the 1994 FSM as a start many things are similar:http://www.phatg20.net/modules...id=62
