Today I was going to run a fuel pressure test because I have been having some weird problems with my car.... I had to help a friend move some stuff and then I said what the hell I will clean this disgusting mess called the sunroof on my car.
So I used 100+ Q-tips, 4 rags, 1 (16OZ) bottle of oil eater and two brushes.
Let me tell you the pictures before are too embarrassing to post but really I should have taken pictures. The end result after a couple of hours is night and day because it looks brand new!!! I will tell you the grease was brown and I was embarrassed to keep the sunroof open.
I think I did too much cleaning because after re-greasing lightly (compared to twenty pounds worth) the sun roof is hard to close, So I will look at it tomorrow AGAIN! and take pictures for you all.
So if your sunroof does't work smoothly check and clean the rails first then re-tighten the clutch on the motor (Much hard to remove and re-tighten).
