infiniti q45 pcv valve replacement
lraysr
Car: 1995 Infiniti Q45
ive read on another post that a pcv valve could be a problem if clogged and could cause the valve cover gasket to seep oil is this true if so i can't seem to locate it could someone help me out?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
I don't recall the post to which you refer. But I am willing to bet your VC gaskets are toast.
Q451990
lraysr wrote:ive read on another post that a pcv valve could be a problem if clogged and could cause the valve cover gasket to seep oil is this true if so i can't seem to locate it could someone help me out?
Welcome to NICO! The PCV valve is located under the trim covers at the front of the engine. You need to download your FSM (factory service manual) - it'll tell you were to find the valve and show drawings. You can get it here.
That said, I agree with Brian... much more likely that your rocker cover gaskets need to be replaced.
Heath
lraysr
yeah you right but im trying to buy time i just bought the car replaced brakes all four and upper links already broke a bolt off trying to tighten valve cover gasket right around the chain link the oil is only seeping out though. Can you see the pcv valve or do you have to remove the plenum?
Q451990
No, you don't need to remove the plenum. Be careful overtorquing steel bolts into aluminum heads!
Heath
Q451990
Here's a picture I stole from Q45.org. I added a red box around the PCV valve.
Heath
lraysr
appreciate it thanks
lraysr
you ever broke one before if so what did you do?
lraysr
i had never used a torque wrench and broke a bolt on my valve what kind of torque wrench did you have?
Q45tech
I've replaced a few PCV valves, but you can clean them with solvents and air. The oil/dirt turns sticky and changes the precise balance point when valve opens at steady speed cruise.
As rings wear, the added blowby fouls the PCV FASTER so annual cleaning gets to be a requirement!
The valve should rattle [as brand new] when removed.
Q451990
lraysr wrote:i had never used a torque wrench and broke a bolt on my valve what kind of torque wrench did you have?
I'm not sure which bolt you broke. If you're talking about one of the valve cover bolts, then I really don't know how to fix it. My understanding is that the 94+ had studs on the heads and nuts actually hold the rocker cover to the head, so if you broke a stud, that's going to be fun.
I assume they're threaded in to the head but I don't have any experience with them since the 90-93 design is different. It would be worth your time to take a picture and post it here so that we know more of what you're dealing with.
Heath
lraysr
my dad has my camera right now but if your facing the engine its on the right second valve bolt back by the MAF on the bottom the bolt is a 10mm bolt. I snapped the head off, do you think when i finally replace the valve cover gaskets the cover will come off easy or will it be a problem or should i try and remove the 10mm bolt first never replaced valves gasket before
lraysr
do you have a step by step on how to replace those vc's please
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
In the FSM.
Hopefully you can extract tthe broken stud and replace it.
You can get another from Joe and the crew
http://www.infinitpartsusa.com
