To make sure we are all on the same page and getting close to the same numbers make sure your settings are as follows:
When using ECU Talk (Any version):
If you don't have ECU Talk:
1.) Download ECU Talk to any folder you want.
2.) Run ECU Talk you do not have to connect to the car.
3.) You will see a new file created called (ecutalk.ini) without parenthesis.
4.) Download this file to where you saved the ECU talk program and overwrite the original (ecutalk.ini) file with this one:
http://dl.dropbox.com/u/146957/ecutalk.ini
5.) Now you can run ECU talk with any sensors you want to select.
If you have ECU Talk downloaded and ran it once already:
1.) Go to the folder the ECU Talk program is located.
2.) You will see a file called (ecutalk.ini) without the parenthesis.
3.) Download and copy this file to the directory the ecutalk.ini file is located so that you overwrite the original ecutalk.ini file:
4.) Start ECU Talk and select any sensors you want and start recording!
The only things I changed in the new ecutalk.ini file:
The number of cylinders (8)
Injector size (370 cc)
Offset the timing display by 35* Before Top Dead Center (BTDC) so it reads (15* BTDC)
Also the I made it so the gauges in ECU talk somewhat match the OEM 1990-1996 (G50) gauge colors. And Imperial units are used instead of metric, You can change that your self in the ecutalk.ini file (Just set it to False).
COM port 4 is used because thats what I use, But you can easily change that.
Auto Connect is disabled.
Matt (Matt1979) sent me 60 MB of logs, Rusty Bucket sent me 18.4MB worth of logs and screen shots, Owner CS is in the process of sending me some logs. So far I have 100MB of logs!!!
I will host them on Google Docs or Drop Box, unless anyone has a better suggestion?
Thank you Lino, Matt, and Rusty
