anewstartinchrist »
https://forums.nicoclub.com/anewstartinchrist-u313579.html
Sat Jul 26, 2025 3:46 pm
Hope all is well and everyone is have a good weekend,
I went to start my 2012 M37x today and the vehicle was dead. The car didn't even unlock(proximity key works) and I had no lights on in the car. So I had to use the key in the fob to open everything. I checked the connection of the battery and everything was tight. I got my battery jumpstarter and it fired right up. I didn't have any lights on the dash but I used my Zurich code reader to see if any codes came up. None did, until I used the Infiniti OEM enhanced feature and one code appeared, P1553 Battery Current Sensor. I decided to test both the battery and the alternator which tested fine. I tested the battery first before the car got to operating temperature. Then once it did, I tested the alternator, but followed the prompts to the T on both procedures. I decided to clear the OEM enhanced code and it didn't come back. I've been checking every so often throughout today to see if I can replicate the issue with the car going completely dead but approaching the car, unlocking it, and starting the car is normal. I will have to let it sit overnight again to see if it happens in the morning. I did charge the battery(and did the 12V repair) with a Noco Genius 5 about a week and a half ago and it's from 2023. The only other thing I did different when reinstalling the battery is cleaning the positive and negative terminals and adding dielectric grease. I also cleaned off the purple grease that was there which my dad had me place all over everything a few months ago, including the fusible link assembly. And ideas?
