If I were to give you a quick answer, it would be
9.8 volts-14.8 volts for the M56 I drive most.
I would like to be a little more specific though.
So apart from the low-ish voltage readings, did your car exhibit any other symptoms? Did your battery keep dying, or what exactly brought your attention to the charging system?
Unless I missed something, it seems like you have only replaced the alternator but not the battery itself, correct?
For example, here are results from my 2011 M56S with around 95k miles. It has a 750CCA AGM battery from NAPA that has been in use for approx 2 years. I don't have immediate access to the exact duration and mileage, but the car has been operated in the midwest since the battery replacement.
I got these results on a Fall day with an ambient temperature of 32 degrees F.
I collected 4 types of voltages:
- Battery voltage before starting the car
- System voltage while starting the car
- Voltage with the vehicle at idle, and no loads
- Voltage with the vehicle idling, with electrical loads
I tested the vehicle at these different states:
- At the first start of the day after the vehicle had sat undisturbed for a day.
- Immediately after test #1, I turned it OFF then ON again.
- After I drove around town, and made sure I did not cross the 8-mile mark. This was a normal commute with traffic lights plus a few shut-offs & start ups as I ran errands.
- After I drove further out of town, and accumulated over 8 uninterrupted miles.
- Immediately after testing #4 above, I shut it OFF then ON again.
I did these many tests to show that different testing and operating conditions could result in
slightly different results from one vehicle to another, and even within a specific vehicle.
The battery tester I bought from AutoZone would indicate normal or high for certain voltages, so I made a point to note that down in the chart. It never once showed low.
For the sake of data integrity I find it beneficial to post the entire chart rather than just handpicking my favorite combination of numbers.
