Infiniti M35x Stereo Amplifier
british columbia
Car: M45 INFINITI 2006
Hey, I was just curious to know if there is a point on buying a brand new stereo amplifier which would cost about $1,300.00 at the Infiniti Dealership parts and labor for my Infiniti M35 of should I just buy one on Ebay which cost about $150.00 - $300.00 for the stereo amplifier, plus $110.00 to install in my car.
Im just worried that if I buy one from Ebay or online, it might have a malfunction (brake in other words) few years ahead?
I just bought an Infiniti M35x 2006 fully loaded, like brand new other then my stereo amplifier, please feel free to let me know on you think.
Larz
Car: 2019 Q70-L RWD
It's my understanding that the amplifier the car came with is quite tricky to replace. If you buy one on Ebay, I would worry that it may not be compatible with your car, may not be in the best condition, or might be missing programming or connectors that the car requires.
I know that other members have tweeked or replaced parts of the stereo so perhaps one of them will respond with more details.
british columbia
I would of course buy a Stereo Amplifier that would be compatible with mine. I would buy on Ebay an amplifier that would of came from another Infiniti M35 and I would make sure that Infiniti Dealership installs it for me, they would also tell me if I am buying the correct amplifier since I would of course get them to look at amplifier before I would be it. Thanks again for your post!
Ilya
If you are getting a used OEM unit on EBay, that's fine. Just have them double check, and pay labor. Definitely don't buy it FROM Infiniti. Junk yard/ebay is fine.
british columbia
Thanks Larz, and IlyaKol I will look into this and get back to you!
svard75
Car: 06 M35x
definitely buy original not aftermarket. Our amplifiers are CAN bus driven so they have many functions that would not work with a standard aftermarket amp. If you wanted to add amplifiers and better speakers then you'll need to add Hi-Lo converters at each speaker output from the amplifier then add the amps and speakers.
This is a great thread to read through fed-up-with-stock-amp-replace-hu-or-ste ... 79679.html
british columbia
Like I said in my previous post, I will be buying An Original stock 2006 - 2009 Infiniti stereo/Amplifer. Nothing will be aftermarket, only stock.
My question was that is there a point in buying a stock Infiniti Amplifier from the Infiniti Dealership which will charge me $1,300.00 cost and labor.
Or should I just buy the same original stock Infiniti Amplifier Online Ebay for $175.00 - $250.00 for the Amplifier itself and $100.00 labor to install the part on to my M35. Only difference is that it is in used condition. Don't know how good of condition it is. Once again I will be buying a compatible one
Larz
Car: 2019 Q70-L RWD
Seems the worst that can happen is you will pay about $300 and find out the Ebay amp doesn't perform. Personally, I think it's worth the risk to save over $1000 on a new amp. Plus, if Ebay gives you a guaranty, you could get the purchase price refunded.
I assume the amp will come with the wiring harnesses intact so installation shouldn't that difficult aside from getting to it.
british columbia
On Ebay I have seen a few that have the wiring harness intact, but other ones don't which of course are cheaper. Once again thanks for your comments.
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Looks like you got your answer up here ^^ :dblthumb: definitely worth a try on eBay!!!
