gotgarth »
https://forums.nicoclub.com/gotgarth-u65832.html
Tue Jul 17, 2007 7:14 pm
1991 infiniti m30 hesitates at low rpm and when transmission up-shifts causing high engine rpm to drop to lower rpm's (but the rpms keep dropping to 300-400 until the computer corrects. but can sometimes get bad enough to intake backfire.) anyway my question is even though i've set the initial timing to 15deg btc with a timing light, my diagnostic programs (connected w/cable and laptop) gives a 55 deg btc reading at idle. (goes up to 80 deg btc with revolution to 2000+ rpms. ) is 55btc normal reading for the car's computer? engine rpms gives trouble in neutral gear no load with slight gas pedal push. i have to hit gas pedal 1/2 throttle or more to take off (fast) decently. (or very lightly and hold until cruiseing up to speed) this all started a day after racing hard across a bridge. new plugs, cables, rotor, cap (yes autozone) and time adjust helped for about 3 weeks. timing belt replaced also. problem just came back again worse. today was the frist time the car hesitated to start (kind of double started in a 1/2 second interval) otherwise starts and idles good. have the car 17mos now, ran good mostly except for only getting 10mpg. replaced oxygen sensor early on after getting the car but no difference in performance. no engine check lights. code 55 every time. exhaust smells kind of chemically. k & n air filter gave a rotton egg smell after heavy throttle racing, but returned to normal afterwards. maf, throttle sensor, injection timing all within service manual specs. plug #6 was black with carbon deposit. all others white. should i mess with taking out the distributor and turning it to try and get a 15btc? or can it only be installed one way?
