Test i preformed on vehicle
-Compression test of engine (Came out good in spec)
-ohm tested my injectors resistence (good all in spec)
-check coil resistence( its good all 6)
-inspected spark plugs ( they are NGK's that were put 3 months ago i found out that they are a little carbon fouled which is due to the vehicle running rich)
-now i was going to do a fuel pressure test but i cant the car does not start so i checked the resistence in the pump itself and it was good.
Now you must be thinking how do i know they are in spec? well i have the alldata software for my car. i know the specs of what the part suppose to be. I was talking to a tech at my local infiniti dealer and told him all the test preformed and what the car is doing. I told him about the o-ring issue he knows of that problem but he told me it can also be the injectors as well since they might be staying open the whole time flooding the engine. So my injectors may be working but he said if the gas in the vehicle is bad and filled with dirt then that dirt may stick inside the injector causing it stay open when its suppose to close causing it to leak fuel into the chamber. I came back home and did one last test. I removed the fuse for injectors and fuel pump and guess what the car started smooth like nothing thats how much fuel there was in the piston chamber. then with my dad in the car i put the fuses back and the engine was hesistating like crazy it was shaking like crazy the only way it stayed on was my dad pressing the gas pedal and when he let go of it the engine stalled. after that i smelled lots of fuel. right now im removing the intake plenum to change seals and injectors. already ordered parts. Im just asking if anybody experienced this same problem and what caused it?
My experience:
4yrs working on cars
went to a vocational school for 2 yrs to learn automotive technology (did dual enrollment in high school for 2yrs)
worked at a shop since graduating high school
im 18 and love working on nissans (vehicles at my house are a 96 g20, 94 J30, 98 Q45, 92 Q45, a 2000 mitsubishi montero sport 3.5 and my current project car 1990 300zx twin turbo) So you see im use to working on imports especially nissans
