An aftermarket will connect directly to the Bose amps (I've done it without any issues in my brother's G20). There are no issues with equalization, compatibility, or anything else. In fact, there's a dramatic improvement in audio quality right off the bat.
The Alpine system installed in my Q used the Bose amps for about a year until the amps started squealing. The last owner then decided to pay for a complete rewire.
Once the amps die, you can begin replacing speakers. You do NOT have to install new amps, run new wires, or buy new speakers right off the bat, but you should anyway since you'll be doing it once the remaining Bose bits go south.
$120 buys you a LOT of head unit now. The installation process requires a $10 wiring harness adapter, normal for any aftermarket stereo installation and available at any Wal-Mart, a $2 pack of wire connectors from Radio Shack, and 15-20 minutes of your time to connect the aftermarket harness to the vehicle-specific adapter. Diagrams are included and wires are all color coded so you can't screw up.
You can also pay a local shop $20-$30 to do the wiring if you provide the harness adapter, leaving you with the simple task of plugging the radio in and putting the dash together.
Here's my Crutchfield review:
http://www.crutchfield.com/S-J...0#Tab
Its a matter of spending $50-$70 for the same old crap or $120 for something new. No rewiring, no crossovers, no new amps, no shenanigans, just a simple choice.
elwesso wrote:UNfortunately, its going to cost more than that to properly hook up an aftermarket HU to the bose.
$120 for a new decent HU and 4 decent speakers? For a decent HU you'll be looking at 50-60, and then you have to install new speakers..
