infiniti i30 no sound
micklepickle
Car: 1999 infiniti I 30
Just recently purchased a 1999 Infiniti I30. The radio/cd changer will turn on and change station but no sound comes out? Where do I start?? Any ideas? Thanks
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Is it the factory radio or an aftermarket unit?
micklepickle
It's a factory 6cd changer.
micklepickle
Ok I have replaced fuse #62 and still no sound.the power antenna goes up,power comes on,you can change stations and from radio to Cd. Just no sound. Is there anything else I can check?
float_6969
I have a similar issue with my 240sx. My rear speakers just stopped working one day. I figured out that the amplifer is falling. You might see if it has a fuse.
micklepickle
No fuse in #22. Put one in and radio comes on for about 2-3 seconds then blows. This supplies power to the audio components via audio amp relay. Amp bad?? Where is amp located?? Thanks.
float_6969
It does sound like a bad amplifer. Mine is located in the trunk, under the rear speakers, but yours might be in a different place.
micklepickle
Can someone tell me what the amp looks like and where to find it.
