Infiniti I30, 2001 problem on Engine
xlpan
Car: Infiniti I 30
One day after I changed engine oil and air filter at a local store, my car cannot start without push the accelerator pedal, and it will stop after release the accelerator pedal. I do not know what cause this. What should I do? Is this just coincident with oil change? Thanks for your wisdom and suggestions.
I pulled the car to the Infiniti dealer last Monday, and they still cannot figure out what wrong it is exactly after one week. The guy think it is a communication problem of the computer system and he want to replace the computer system. $$$ . Any suggestions?
Helpppppp!!!!!!!!!
They had changed air intake sensor so far.
Modified by xlpan at 6:38 AM 3/20/2006
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
Did you check to see if you possibly left a hose loose or disconnected when you changed the air filter? That's what it sounds like...
xlpan
Car: Infiniti I 30
Thanks, Ginknave. What kind of "hose"? The air filter is in the slot and it seems be tighten by the pin attached to the slot.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Yeah, the filter is a breeze to replace. Just two latches, and pull the filter bracket up. Replace the filter, and latch it back.
It sounds like a coincidence, unless somebody dropped a rag in the hole.
xlpan
Car: Infiniti I 30
Helpppppp!!!!!!!!!
Raxephon
Car: '04 RX8...for the moment...
xlpan wrote:I pulled the car to the Infiniti dealer last Monday, and they still cannot figure out what wrong it is exactly after one week. The guy think it is a communication problem of the computer system and he want to replace the computer system. $$$ . Any suggestions?
Helpppppp!!!!!!!!!
2001 Infiniti I30 Factory Service Manual (Free & in pdf form)http://phatg20.net/modules.php...d=196
Are all the hoses in good shape and connected correctly?
Are all the electrical connections plugged in correctly and undamaged?
Are you getting any codes from the ecu?
As you release the acelerator what rpm does it run at before it dies?
Does the tachometer needle bounce?
xlpan
Car: Infiniti I 30
Are all the hoses in good shape and connected correctly?Are all the electrical connections plugged in correctly and undamaged?Are you getting any codes from the ecu?
No sure.
Some time the car will run well, rpm ~1k. But sometime after start it will die immediately, rmp ->0 right away, and the tachmeter needle did not bounce at all.
