INFINITI I30 2000- STARTS AND THEN STALLS OUT
VIKING43
Car: INFINITI I30
The car starts right up. As long as I keep my foot on the gas the car stays on. As soon as I take my foot off the gas the car stalls out. What could be the cause?
Kompresshun
Welcome to NICOclub!
First of all - is the check engine light on at all? It could be a lot of different things based on how you described it, so has it showed any signs before this happened?
My first guess would be the MAF(Mass Air Flow) Sensor or the fuel pump, but without more information it's really hard to diagnose the problem.
VIKING43
Car: INFINITI I30
The check engine light did not come on. The car showed no signs of a problem before this
Kompresshun
After looking at your description again, it sounds like your alternator may be bad. Have you had any problems with your battery recently, like maybe having to jump the vehicle off after it sitting overnight?
VIKING43
Car: INFINITI I30
No Issues with Battery
Kompresshun
Without it throwing any codes, or having any issues with charging, it's hard to say what it could be. It would really be taking a shot in the dark, considering the amount of possible things that might be wrong. The alternator or fuel pump would be my guess, but you would have to do further testing to find out for sure.
I'll have to let some of the other guys chime in on this one, so hopefully they can help give you a better answer to your issue.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Without a troule code, it may be difficult to diagnose. What was the last maintenance activity done in the car?You can start by checking the entire air intake for any leak. Such leak will cause starting problem. Check air filter and replace if dirty. Clean the MAF sensor and connector (CRC MAF sensor cleaner will do, then apply dielectric grease on the connector pins). Clean throttle plate and body (do not spray directly into the assembly, use rag).
Make sure the main engine harness ground points are clean. If not, remove and clean both the lugs and the ground points. Apply dielectric grease after cleaning. Just follow the main engine harness and you will find two small black wires going to the engine frame.
If you suspect a faulty MAF sensor, disconnect it and start the engine. It will turn on the CEL (most likely P0100 code) but can be reset later. The car will be in 'limp mode' with the plugs and injectors firing simultaneously. Do not drive the car in this condition. So if the the engne runs, then you have a bad MAF sensor.
The problem may also be with the IACV. Refer to the 'sticky' within this forum on how to clean/replace it. BTW, if you have a shorted stepper motor coil(s) in the IACV, it may 'kill' the ECM (driver/power transistor is inside the ECM).
If all of the above did not fix the problem, check the fuel pressure - 34 PSI with engine running; 43 psi with engine off, Ignition ON (limited to 5 seconds). You need to connect a T-fitting on the line going to the fuel rail. You can buy it or borrow one from Autozone. FIRE HAZARD - ensure fuel line is empty before you break it (pull the Fuel Pump fuse, and crank the engine several times).
VIKING43
Car: INFINITI I30
Thanks - I will check through all you have suggested
dancad
I have a similar problem. A 99 that has a surge then drop in rpm once started almost to the point where it stalls....has been showing a low idle when at stop lights as well. No cel....
