Infiniti G35x Driver Side Door won't open
jmcarr33
Car: Infiniti G35x Sedan
Can anyone help me please? I have a 2007 G35x and my driver side door will not open from the inside or outside. The key doesn't work and I am not even sure I can fix it with the door being locked shut. The handle on the outside feels slightly loose as well. Thank you in advance.
13_SkylineSedan
Car: 2x 2013 G37 sedan 2WD-7AT (his and hers)
start on page 207 of this book:
http://www.nicoclub.com/manuals/G35/Sed ... an/dlk.pdf
to see the mechanical workings of the door.
I've heard of outside handles failing because the "cylinder lock rod" falls off, or sometimes the handle breaks at it's own hinge points. But it seems unusual that both inside and outside have quit working at the same time unless the "doorlock assembly" itself has busted. Good luck.
jmcarr33
Thank you.
