Infiniti G35 Hood hinges problem
LRT
Car: 06 Infiniti G35
I have an 06 G35 and I'm unable to open the hood. It appears that the hinges are froze up. Have tried some lubricaating oil but no luck.
Suggestions?? able to fix or replace.
thanks
LRT
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
My pass. side started freezing up on me (04 coupe) a couple of months ago.
I bought one at my local Infiniti for around $32.
Next, primed and painted it (rattle cans from Autozone....dark blue was pretty close to my TB).
Installation.
Open hood.
Remove bolts holding top of fender on.
Remove bolt from fender inside door jam.
Have somebody hold hood from front.
Remove bolts from hood (after scribing where hindge is on hood).
Pull back on fender and remove bolts holding hinge on
Replace hinge bolting it to car then bolt to hood.
TA-DAAA!!!
repeat on other side.
Welcome to Nico!! :cheers:
LRT
Thanks for the info!
SVTCOBRA
Welcome!
And, I did soak the old hinge in white grease after I took it off just to see if it would loosen up, but didn't seem to do any good.
So don't know if anybody else has had any luck with fixing the old hinge.
telcoman
SVTCOBRA wrote:Welcome!
Had to replace mine at 101599 miles in Nov 2009
Telcoman
LRT
I have approx 135,000 miles,still runs great! was able to loosen them up but still ordered the parts today. Thanks LRT,
audtatious
Weird...I would not expect a hinge issue
SVTCOBRA
WHen I was shopping for a used G35 Coupe about 3 yrs ago I happened upon one at a lot that when I opened the hood, the hood got in a bind with the fender near the hinge. The hood popped by it and I noticed a scratch on the fender where it did this.
I immediately thought that it had probably been in a wreck and somebody didn't align the hood properly.......until this started happening with mine.
I replaced my pass. side and bought a can of white grease to shoot on the other side.
