Infiniti G35 AC Compressor Problem
infg35ac
The AC compressor is fully functional, but does not work while the fans are running. What steps should I take to troubleshoot the problem?
telcoman
infg35ac wrote:The AC compressor is fully functional, but does not work while the fans are running. What steps should I take to troubleshoot the problem?
Probably an automotive air conditioning expert or the dealer
http://www.nicoclub.com/FSM/G35/Sedan/2008/HA.pdf
Telcoman
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Welcome to NICO. First thing you'd want to do if you're comfortable with it is to put some gauges on the system and see what it's doing. Chances are the pressures will not be what you'd expect, and depending on what is happening would determine what the likely cause would be.
