Hi Guys.
Would be grateful if anybody of you could explain a solution to below problems. My car is 2009 Model FX50s. 130,000. KM on it (Bought one month ago). Below are the problems i am facing..
1) Humming/Buzzing noise while i press the gas pedal. There is a humming sound coming while driving above 40km from underneath. When i don't press the gas pedal sound disappears. Sound is not there when i put in to neutral while driving. Tires are a little old. is tires are the problem or something else.
2) A slight vibration while hard acceleration. This happens only if i am driving at very high speed(stop and go drive). No problems while normal speed acceleration.
3) When i turn the AC on i could feel car is moving forward at signals even though i press the brake.
Thanks guys..
