Infiniti FX35 overheating please help!
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
skyline2693
Car: 1995 Nissan 300ZX Twin Turbo
ok so I got an infiniti fx35 2007 model and couple of days ago it overheated... not badly because as soon as I saw it overheting I pulled of and turn her down, so I brought her home replaced the thermostat and when is at idle it runs perfect, but as soon as you take it for a drive it overheats really bad, alrady replaced thermostat and rad cap, I bleed the cooling system as with the plug in the hose please help!!
PapaSmurf2k3
Site Admin
If you turn the heat on when its overheating, does it blow hot air?
You might just have to bleed it more.
skyline2693
It blows cold air, and everytime I come back from a ride there is coolant all over the place
PapaSmurf2k3
Site Admin
Yup, sounds like there are still air bubbles in there. Try bleeding it a few more times.
fx45_nismo
It can be that your radiator has debris on it. I had that issue and now it's back to normal
FXDodger909
Car: 2006 Infiniti FX35
Im having the EXACT same issue right now as we speak. I also changed out the thermostat and rad cap w/ coolant and washed down the radiator. What i need help is, where is the Air bleeding valve located at????? i cant find it at all...
Also my issue is that the hose from the radiator to the motor is hot (as it should be) BUT the hose from the radiator to the "new" thermostat is not as hot as it should be and im not sure why.. A buddy of mine told me to just take the thermostat out completely but i don't know about that. There's no leaks from the radiator/hoses/claps or belts so im not sure what else to do.
If someone could give me some type of advice or shine some light to this i would really appreciate it.
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
