Infiniti ex35: red light underneath drivers side mirror
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
Drco
Car: Infiniti Ex35
After stopping the engine I noticed that there is a red light that appears under the driver side mirror. What could cause this? This is not the welcome light as the welcome light is more like a white light.
I tried settin the alarm on and off but it still happens. Any idea and how to fix this?
Hope someone can help as I'm afraid it may drain the battery.
Thanks.
Reason: Typo
XIS
Car: 08 Infiniti EX35 RWD
17 Infiniti QX30 Sport
never heard of that???
CustomLowz
Car: 2011 Infiniti EX35
I have never heard of a red light either. I have a white light (puddle light) under my drivers mirror
XIS
sounds like someone might have changed the LED bulb from white to red... are there any other lighting mods done? Did you buy it used?
Drco
Car: Infiniti Ex35
It's new. One of my driving light is busted so could that cause the problem? The link ght is just a small red dot, not like the puddle lights
jakenbake
Car: 2009 Infiniti EX35
Picture?
Bbreeze
Car: Infiniti ex35 2009
I have the same thing, except mine is not flashing, it's always on.
It's white when I get near the car with my keys, but when the light (white) goes off, the red light stays on forever. (2009 Ex35 AWD).
Any clues.....anyone?
Bbreeze
Bump
Bbreeze
Solved,
I have to mention that things got worse before I found what the problem was.
Electric seat (driver's side), mirrors, cabin light, and electric steering stopped working. Happened before, about 2 months ago. All I did was replace a 10a fuse in the electrical box and problem solved.
Except this time when I replaced the fuse it burnt the fuse right away. Took the car to my Infiniti dealer, luckily the mechanic found the problem in a few minutes. There was a short in the driver's side sunvisor light. Disconnected the wires....problem solved.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
