C-Kwik wrote:As far as tires, the fronts you have now are smaller in diameter than the OE rear size. To keep the VDC happy, you must run the correct size ratio from front to rear.
Is the diameter the 2nd number? (Current Front: 245/40 ZR18) If so, the previous owner was already running with tires with a smaller diameter
(Stock Rear Specs: 245/45 R18 96W) so will the 45 to 40 cause a problem? (Rex said it's doable)
Does anyone have any input on the Yokohama AVS ES100? Priced at 136 each for Front: 225/45ZR18. My main issue with the current Michelins is the road noise, any members here have any tires they currently use with little road noise?
About the brakes. It seems everyone is recommending Hawk brake pads. Which Hawk brake pads to get depends on which rotors I go with, correct?? Wheres a good website to order Hawk brake pads from?
From the site you mentioned, are these OEM Infinti parts? If so, I would be w/o sport correct since I do not have Brembo brakes?ROTOR, G35, w/o Sport 2003 $78.39ROTOR, G35, w/Sport 2003 $389.16
Oh yeah, I just remembered they said I need my air cabin filter changed, $90 a filter, does anyone know how many I need and where I can get for cheap?
