Infiniti 2002 Q45 ignition key
litemy9tup
Car: infiniti 2002 q45
My car is an Infiniti 2002 Q45. I recently noticed that the ignition key always a little stucks when I'm trying to pull it out. I'm just wondering if it's a simple sign that the juice of the key battery is running out, or the remote is having a serious problem. I have 2 keys, however one of the keys can only open the doors, and the other one can only ignite. If it's a MUST to get an extra key?Thank you for your idea!
troy3399
Car: 1995 Q45 122000
Are you sure it's factory key that got stucked? Most after market keys get stuck since it's not properly alight inside ignition lock. Use 300 grits sand paper sand both sides of the key smoothly ( dont sand too much just take roughness out of it) make sure stray some W40 when u done. Enjoy your new modded key.
troy3399
The purpose of sanding make the smooth and reduce friction when u try pull the key out.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
The F50 (02-06 Q45) uses an integrated remote control and ignition key, with a detachable key for the door and glove box. It's not like the old-style metal key for the ignition switch. Per his info, technically, he has only 1 set of key. I'm not sure what happened to the other set of keys.
Make sure the tip of you ignition key is clean (do not sand). Also check the car battery - should be >12.5 VDC with engine off.
mcrews
Car: 2002 Q45 Sport
actually, it's not a key, and you damn well better not sand it!!!! reallllyyyy bad advise.
It's a remote with a nub. NO KEY NO METAL NO SANDIthe nub sticks in about 1/2 inch. the 'key' is an electronic chip in the nub.
The is a metal key hidin inside the remote incase the battery in the remote dies. If used that key all of 3 times in 178000 miles.
troy3399
mcrews wrote:actually, it's not a key, and you damn well better not sand it!!!! reallllyyyy bad advise.
A monkey finally figure out what his keys are made of.. very impressive
mcrews
Car: 2002 Q45 Sport
hey newbe,
quit trolling and giving incorrect advise
a beater and 25 posts don't qualify you to be a smartass yet.
a better reply would be.....wow I learned something today.. ...problem is you probably can't learn......
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
This thread is already a certified, registered, licensed classic!!
mcrews
Car: 2002 Q45 Sport
troy3399
mcrews wrote:hey newbe,
A good mechanic is the one with long time experience in the real world. I'm apply my experience help others get problems resolve, sometime my anwser are not the best.
And you sound like a preteen kid haven't reached your puberty yet with no experience in real world and still getting daily doses of breasts feeding. Listen kiddo, consider yourself lucky you're getting free education from me.
