Infinifi Headlight
wondervu
Car: 2006 Infiniti G35X
Can anyone give me some help with how to change the headlight bulb on a 06 Infiniti G35 sedan? Thanks
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
The easiest way to do that is to remove the front wheel(s) and the plastic trim clips and 1 screw securing the top section of the inner fender liner. Once you can pull the liner down 6-8 inches you will be able to see that back of the headlight assembly. From here you will see a circular cover, under the cover is the high current connector. Once you have disabled the headlight, ideally by disconnecting the battery, a 1/4 turn will unlock the terminal connector. After that you will see the rear of the bulb.
The next step is kind of a PITA and the best reason for doing this from the underside. Unlock the thick wire retainer. After that pull the bulb straight out. Note the exact location of the tabs when you pull it out to make installation easier and guarantee you get the best results possible.
Installation is pretty much reversing the above.
Good Luck.
