P0774 - Torque Converter Clutch Circuit Intermittent / Shift (Solenoid E) Intermittent
Symptoms - Slow start, slipping
Causes
- Faulty torque converter clutch solenoid valve
- Torque converter clutch solenoid valve harness is open or shorted
- Torque converter clutch solenoid valve circuit poor electrical connection
- Low transmission fluid level
- Dirty transmission fluid
The P0774 Nissan code is detected when the gear required by the ECM does not match the actual gear when vehicle is driven.
Most of what I've seen is this is related to Nissan's service bulletin: http://www.autocodes.com/uploads/nissan/NTB09-148a.pdf
In there they mention what Nissan will do with this code:
ACTIONS
• Replace the Control Valve Assembly
So transmission from LKQ maybe flawless,but valvebody or solenoid appear to be bad.
Headed to LKQ again to find another and give that a go with another fluid flush.
**NOTE**
Also found to get the right filter for the inside I just tell Autozone its for a 2008 Dodge Caliber 2.4 (part number TF495) vs my 08altima that pulls the wrong internal filter (part number TF633)
I'll report back on this. Anyone that's been through similar please report back fix, wanna make sure I'm not wasting time on the valve body when the transmission is going (however it does shift NICE until that damn code).
Also wondering if "service bulletin" is the same as a recall or simply the "what to do with this problem" notes for Nissan techs?
