Infamous J30 Rust Spot
VimyJ
J owners are most likely aware of the rust spot that develops on the bottom left side of the car at the weld point. I got a quote of $400 to put new metal in there. Sound reasonable? Guess I could get a couple more quotes but this guy is a connection through my tech.
The "spot" is about the size of the palm of my hand and has, alas, rusted through. I want to keep the J for another 100k so I better get on this before this rust spreads like a southern CA wildfire this winter.
I was on the road when the spot became a problem and my wife took the J to a dealership as it was still under warranty. They gave her the run around and when I got back from my travels the 7 years had elasped.:(
cweberj30t
Car: 1993 J30t
2003 G35
2007 G35X
2011 G37X
I'm not sure where exactly you are talking about. I am interested since I just touched up a couple of spots on mine. A picture would be nice.
VimyJ
Underneath on the left side down near the rocker panel past the passenger door where the two pices of body sheet metal join. I've seen quite a few J's with rust in that spot. Hopefully, you lucked out and got a superior weld. Seems like the guy who was doing that work on the line overheated the metal and compromised the rust proofing.
