Infamous Gas Smell
alex61089
Car: 1993 Infiniti J30t (crashed)
2006 Nissan Altima SL Special Ed 31K.
So wrote a post a little bit ago about a gas smell in my car so um yeah.. i need help or any past experiences with it if you guys had any... heres the facts:It's coming from the trunk (the gas tank)I can hear fizzing like the vapors are leaking outI replaced the fuel pumpI replaced the O rings for all 3 fuel lines on top of the tank.
any suggestions?
alex61089
BUMPPPPP When i turn the air on and it is on for a bit i start to smell strong gas
yodawill2000
Car: 94 Infiniti J30
If its coming through the vents I would think the leak is in the engine bay.
alex61089
Yeah but the problem is that the smell isnt coming from the vents but i guess because the air is on and the windows are closed the smell lingers and gets stronger.. I definitely smell it in the trunk and i can hear fizzing.. Are there any lines back there that could be cracked, ect; or perhaps the tank it self is cracked?
yodawill2000
Have you taken the panels off and took a good look at the tank and the hoses ??You said turning the AC on made the smell stronger so I assumed it was coming through the intake vents, which are at the base of the windshield , not in the trunk.
alex61089
yes the smell gets stronger but i believe being as the gas tank is in the back.. The leak is pouring into the cabin and because the windows are closed it becomes strong.
WA261
Car: 96 J30
Mine turned out to be the lines on top of the fuel pump were not tightened enough.
