EW »
https://forums.nicoclub.com/ew-u28959.html
Sat Jun 11, 2005 3:04 am
I'm glad you posted. Remote start on a 5 speed is NO PROBLEM if you use products designed for it. Cliford G4 and G5 products require you to go through an exit procedure which makes you leave the car in neutral. If you do not go through the exit procedure, the car will not attempt to start which will prevent the picture you posted. It is safe and works great. I've owned and sold the for YEARS.<--- Will install remote start on a 5 speed all day long.
