ddgsxr504 »
https://forums.nicoclub.com/ddgsxr504-u24314.html
Tue Feb 15, 2005 10:07 am
I HAVE INDIGLO GAUGES MYSELF, IF YOU ARE GOING TO WIRE THE GUAGES UP, DO IT RIGHT NOT RICE. GET A CHILTON OR FSM AND CUT A SECTION OFF OF THE PLASTIC WRAP UNDER THE STEERING COLUMN WHICH CARRIES THE HARNESS FOR THE IGNITION AND LIGHTS. FIND THE WIRING DIAGRAM AND LOCATE THE POWER (HOT) WIRE FOR THE PARKING AND HEADIGHTS SPLICE THE POWER (HOT) WIRE TO THE INDIGLOW GUAGES INTO THAT THEN RUN A THE GROUND FROM THE INDIGLO GUAGES TO THE CHASSIS BEHIND THE KICKPANEL ON THE DRIVERS SIDE, WHERE THE FUSE BLOCK IS, THEN YOU ARE DONE. ANY QUESTIONS LET ME KNOW.
