Indiglo Gauge Installation
BooFa
hey... i installed my gauges.. but i have NO IDEA which wire is the wire i need to hook up the switch to... like.... to have the indiglo lights turn on when you turn the headlights / running lights on... which wire is this?.. i took apart my entire dash!! tried 8 different wires!! blue/black.. red/black... blah blah blah... WHICH WIRE DO I CONNECT MY INDIGLO GAUGES TO? IN ORDER FOR THEM TO WORK PROPERLY!?!? WHEN I TURN ON MY RUNNING/HEAD LIGHTS!!! ahhh!! i need so much help.. anyone. .PLEASE respons asap!!
- 1992 240sx Fast Back.... =Dplease help me~.. :help
Silvia007
Car: 93 Nissan 240SX SE Fastback
Well, hook it up to the wires that's going into the dimmer switch. There should be a few wires in the switch. From the indiglo gauges, ground the ground wire and get a 12volt tester to test the wires that goes into the dimmer switch to see which ones light up (make sure you ground the tester to the chasis). Make sure you have your parking lights on first before testing the wires. Which ever wire lights up or triggers the 12 volt tester, use that wire as the positive terminal for the indiglo gauges and ur all set. Hope this helps.
BooFa
ok.. so the dimmer switch on the lower left hand side of the dash... anyone know a specific wire?.. color and location?!.. that was a great help.. but i wanna be kinda sure before i take apart my entire car again!.. xP.. thanks ya'll~
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
Lost_To_A_K-Car wrote:Wouldn't it be easier to tap them into the illumination power already going to the cluster?
There is only ONE line out from the dimmer... and that IS the "illumination" power source. Now I'm not going to tear apart my dash to give you a specific wire color.... but if memory serves correctly, there are only 2 wires in the dimmer switch.. one in one out... the dimmer just sets resistance..... either side will provide power... one will dim it... one won't. With indiglow gauges.. I would bypass the dimmer entirely... cut the dimmer out.. and splice your line into both wires..... done!
BooFa
ok... so i'll try to connect it to the dimmer switch~!.. hehe.. if it doesn't work... i'll post up again!. haha.. i hate going to frigging body shops charging like.. 150 to install them.. when all i need to know is which wire to cut!!. haha.. anyways.. thanks for the help ~~ any other suggestions?? .. xP :icesangel
ash1y1
Car: Cars, Gadgets & Gizmos, Computers, Health, Travel
Does anyone make REVERSE indiglow gauges for 95 240sx? I've seen the indiglow version, but the reverse indiglow looks so much better. Websites would be much appreciated. thanks
Anand
ash1y1 wrote:Does anyone make REVERSE indiglow gauges for 95 240sx? I've seen the indiglow version, but the reverse indiglow looks so much better. Websites would be much appreciated. thanks
I have the reverse indiglow on my 95. It looks BAD ***!! here is what I did to install it. I tapped in to my dimmer switch. I just took the console out and that is it. then I just went and got 2 of those tappers form radio shack. and tapped the power into the power and black with the white line into the same. It was very easy. I just have one opinion for you. When you do it, put a few drops of super glue or some type of glue so the new face sticks good. I didn't do it the first time and my temp needle keeps sticking untill I tap my console and then it frees up. So i am going to have to take it out and glue it down. sorry if this was a long reply
OO... about where I got the reversew indiglow... I got it off Ebay for like $29 shipped to my house. was a great deal.. let me see if I can find the link where I got the install direcitons since it didn;t come with any...
ash1y1
Hey Black240, you say you got the reverse indiglow for your 95 240 from Ebay? Because the only ones I can find are for 240s before 1994. The only kind they have for 95 models and up are the standard indiglow. Someone please post a wesbite/link that these reverse indiglow gauges can be found for 1995 240sx. thanks
Anand
there are none at the moment but just wait adn they will pop up on there in a while. I see them on there all the time.
Anand
procarparts.com <~ is the seller that I bought my reverse indiglow from.. hope this helps
Anand
here is a website that might help you install:http://www.geocities.com/pacecarvspec/Install.html
Hey Ashley... I found the auction for you... here is the link.. it is a lil expensive now.. it's up to you to either wait till it gets cheaper or you may want to buy it!
http://cgi.ebay.com/ebaymotors...58759
psyclone69
I just won some of the reverse indiglos off ebay for like 30 bucks, going to try to install today.
