seang »
https://forums.nicoclub.com/seang-u122444.html
Fri Nov 12, 2010 5:47 am
Firstly, this is a well-documented practice easily turned up wth a Google search. Secondly, this might have more of an effect on a SOHC because a DOHC KA has centrally located plugs.
I tried this on my 134hp SOHC truck motor by swapping the plugs around until I found the ones that lined up without the need for indexing washers (one of them is a little off, but the open gap is still generally aimed into the center of the combustion chamber, so I feel okay running it). And the result is not a whole lot more power, but it seems to run smoother when it I peak it out, which is frequently. So that might add up to a few hp, but it was totally free to me. All I did was swap the plugs around until they lined up best, not perfect, but as good as they could be.
I think indexing the plugs increases efficiency by a percentage. For example, 2% of 300hp is larger than 2% of 150hp. But I read so much about people wanting to bolt on more power, more efficiency. This is one of those things people can do, and the only logical thing I can think of is that someone would discredit that it is only a few hp and not 30hp.
After reading, thinking, and finally doing, it seems to me that keeping a $20 set of indexing washers around is no more radical than keeping an extra jug of oil around in anticipation of the next change. And being cheap like I was, you can just get the plugs as good as they will naturally go, without indexing washers, as long as the gaps are not pointing directly at a wall.
seang on Sat Nov 13, 2010 7:32 pm, edited 1 time in total.
