Index of Abreviations and Terms
Q451990
Moderator edit: Heres how this thread is going to work:
1. Reply with your addition(s) to the glossary. They do not have to be in alphabetical order or anytthing, just add something....2. Moderators will add each entry. Once your post is deleted, it has been added to the master list....3. Dont even try and be a comedian and add something not related to Nissan/Infiniti's.
AAAC - Aux. Air Cut Valve (See IAC)
AT or A/T - Automatic Transmission
ATF - Automatic Transmission Fluid
B
CCAI - Cold Air Intake
DDTC - Diagnostic Test Codes
E
FFSM - Factory Service Manual
FSTB - Front Strut Tower Brace
FUCA - Front Upper Control ArmG
HHLA - Hydraulic Lash Adjustor - Oil pressurized roller cam follower adjuster. A modern version of the old valve lifter which used push rods unit.
IIAC - Idle Air Control ValveJ
K
KS - Knock Sensor
L
MMAF - Mass Air Flow sensor
N
O
P
Q
RRSB - Rear Sway Bar
RSTB - Rear Strut Tower Brace
RUCA - Rear Upper Control Arm
SSRS - Supplemental Restraint System
TTB - Throttle Body
TPS - Throttle Position Sensor
TSB - Technical Service Bulletin - Updates to service manual to address issues discovered in the field.
UUDP - Under Drive Pully
V
WWOT - Wide Open Throttle (Pedal to the Metal)
X
Y
Z
Raxephon
Car: '04 RX8...for the moment...
VTC: Valve Timing Control
EGR: Exhaust Gas Recirculation
ECT: Engine Coolant Temperature sensor
EGT: Exhaust Gas Temperature sensor
FIC: Fast Idle Cam
ACV: Air Cut Valve
FPCU: Fuel Pump Control Unit
O2/Oxy/Oxygen Sensor : Exhaust gas sensor
TDC: Top Dead Center
BTDC: Before Top Dead Center
Wes- Added.
Raxephon
PTU: Power Transistor Unit
ABS: Anti-lock Brake System
PCV: Positive Crankcase Ventilation Valve
Wes- added.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Ill leave this post here os that I dont inadvertantly delete the main post...
Got everyones so far, keep up the good work!
ALSO, if you want to expound on any given entry, feel free to do so!
EDIT: I also have the SAE list of terms, and we can add them as we see fit, but id prefer to keep this more with the terminology we use here on the forum/nissan community....
For instance the Camshaft position sensor is mostly called the CAS here on the forum, so id rather use that instead of CMPS.
A/F or AFR - Air / Fuel RatioCEL - Check Engine LightCVT - Continuously Variable TransmissionDOHC - Dual Overhead CamsE85 - EthanolHVAC - heating ventilation and air conditioning systemIC - IntercoolerKS - knock sensorMAPS - manifold absolute pressure sensorOBD I - onboard diagnostics generation oneOBD II - onboard diagnostics, second generationPCV - positive crankcase ventilationSOHC - Single Overhead CamVDC - Vehicle Dynamic ControlVLSD - Variable Limited Slip DifferentialHLSD - Helical ................VSS - Vehicle Speed Sensor
6MT - 6-speed manual trans5MT - 5....................5AT - Automatic
ACTSUS - Active Suspension SystemHICAS - **** I can't remember, 4-wheel steeringATTESSA - see above, all-wheel driveFED - Non-CA emissions car
added- Wes
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
MIL Malfunction Indicator Lamp (The CORRECT terminology for a CEL) CVVT Continuously Variable Valve TimingVVL Variable Valve LiftCVT Continuously Variable TransmissionATTESA Advanced Total Traction Engineering System for AllATTESA ETS Advanced Total Traction Engineering System for All with Electronic Torque SplitHICAS High Capacity Actively Controlled SuspensionMPFI Multiport Fuel InjectionTBFI Throttle Body Fuel InjectionDOT Department of TransportationNHTSA National Highway Traffic and Safety AssociationNMA National Motorists AssociationNNA Nissan North AmericaNMAC Nissan Motor Acceptance CoorporationNTCNA Nissan Technical Center North AmericaTCU Transmission Control UnitHP Horsepower, Unit of Measurement for Power Output (746W = 1HP)Lb-ft Pound-foot, Unit of Measurement for TorqueRPM Revolution per MinuteMPH Miles per HourKPH Kilometers per HourPS Pferdestarke, Unit of Measurement for Power Output (735.49875W = 1PS)RON Research Octane NumberMON Motor Octane NumberN2O Nitrous Oxide (Chemical Formula)NOS Nitrous Oxide SystemsEV Electric VehicleLEV Low Emissions VehicleULEV Ultra Low Emissions VehicleSULEV Super Ulta Low Emissions VehiclePZEV Partial Zero Emissions VehicleHEV Hybrid Electric VehicleZEV Zero Emissions VehicleEPA Environmental Protection AgencyCARB California Air Resources BoardSEMA Specialty Equipment Market AssociationNOPI Number One Parts IncorporatedAAA American Automobile Association
Added- Wes
KATwo40
Car: 1993 240sx KA-T
ATDC : After top dead center
VE: Volumetric Efficiency
MBT: Mean Best Torque
BMC: Brake Master Cylinder
MC: Master Cylinder
CMC: Clutch Master Cylinder
FPR: Fuel Pressure Regulator
RRFPR: Rising Rate Fuel Pressure Regulator
AFPR: Adjustable Fuel Pressure Regulator
added- Wes
EAV - Ethnically Altered Vehicle
KATwo40
CKS: Crank Angle Sensor
CAS: Cam Angle Sensor
IAT (Sensor): Intake Air Temperature (Sensor)
MAP (Sensor): Manifold Absolute Pressure
KS: Knock Sensor
added- Wes
BMNP - Black Midget Ninja p0rn
Added to the Fredictionary- Wes
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
AZhitman wrote:BMNP - Black Midget Ninja p0rn
HAHAHAHAHAHA Oh, and Greg, E85, to be more specific, is 85% Ethanol Blend [with gasoline]
C-Kwik
I/C - Intercooler
FMIC - Front Mount Intercooler
SMIC - Side Mount Intercooler
MAP - Manifold Absolute Pressure
RRFPR - Rising Rate Fuel Pressure Regulator
FMU - Fuel Management Unit - See RRFPR
O/D - Overdrive
NOx - Nitrous of Oxides
CO - Carbon Monoxide
HC - Hydrocarbon
NOS - Nitrous Oxide
BA - Brake Assist
EBD - Electronic Brake Force Distribution
TPMS - Tire Pressure Monitoring System
HID - High Intensity Discharge
NDIS - Nissan Direct Ignition System
Added- Wes
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Chano,
NOx is Oxides of Nitrogen
naed240sx
Car: .....
RUCA- rear upper control arm
LCA- lower control arm
FLCA-front lower control arm
RLCA-rear lower control arm
TC rod - tension control rod (tension rod)
added- Wes
audtatious
ABS - Anti-Lock Braking System
APP - Accelerator Pedal Position (sensor)
ASCD - Automatic Speed Control System
SSV - Shift Solenoid Valve
TCC S/V - Torque Converter Clutch Solenoid Valve
DTC - Diagnostic Trouble Code
LPSV - Line Pressure Solenoid Valve
PNP - Park/Neutral Position (switch)
OVRCSV - Overrun Clutch Solenoid Valve
BA/FTS - Battery/Fluid Temperature Sensor
VSSMTR - Vehicle Speed Sensor Meter
CAN - Controller Area Network
PT/SEN - Power Train Revolution Sensor
DRL - Daytime Running Lights
OBD - On-Board Diagnostics
EVAP (EVP) - Evaporative Emissions System
ECTS - Engine Coolant Temperature Sensor
KS - Knock Sensor
IVIS - Infiniti Vehicle Immobilizer Sysem
ORVR - On-Board Refueling Vapor Recovery
NATS - Nissan Anti-Theft System
NVIS - Nissan Vehicle Immobilizer System
PCV - Positive Crankcase Ventilation
NVH - Noise Vibration and Harshness
TDC - Top Dead Center
POS - Crankcase Position Sensor
onosqv
Car: '92 240sx Vert
don't forget...
TCU - can also be Time Control Unit, which is located behind the USDM driver side kick panel. The TCU/TCM as listed in first post (normally referred to as TCM in 240's, but guess you can interchange) is located behind the USDM passenger side kick panel.
IAC up above is also commonly referred to as IACV.
AIV - Air Induction Valve
Since A/T was listed up there...
MT or M/T - Manual Transmission
N/A - Naturally/Normally Aspirated
CKwik: NOS is NOT Nitrous Oxide... NOS is Nitrous Oxide Systems, a company that makes Nitrous Oxide (N2O) kits.
(only vlsd & hlsd were listed before)
LSD - Limited Slip Differential
** Is someone else using AZHitman's acct w/ his last 2 posts? Or is he just going delerious from all the fumes from his KA-T?
vvvvv Do these count? vvvvv
KA-T / KA24(D)E-T/R - KA24(D)E Turboed or Supercharged EngineKA24E - 2.4L SOHC KA EngineKA24DE - 2.4L DOHC KA Engine
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
I have a list of every production engine Nissan has had, dating back to the early 1900's (well, at least it has most of them). We can add those all at the same time. KAT you may want to add though since it is not a production engine.
C-Kwik
EZcheese15 wrote:Chano,
I thought it sounded wrong. Tried a quick search to make sure, but then I got lazy.
C-Kwik
brokeAs240sx wrote:CKwik: NOS is NOT Nitrous Oxide... NOS is Nitrous Oxide Systems, a company that makes Nitrous Oxide (N2O) kits.
I guess I'm not very Nitrous of anything literate. I guess that's why I prefer turbos!
Raxephon
Why were my posts deleted but none of them added?
elwesso
2007 BMW M Coupe
anlasak wrote:Why were my posts deleted but none of them added?
I added all of yours! If I didnt please let me know.....
I dont think ill delete the posts... just mark them done or something...
Raxephon
elwesso wrote:I added all of yours! If I didnt please let me know.....
BTDC,TDC,EGR,ECT,EGT,VTC,PTU,FIC,ACV,FPCU,O2, are not there.
elwesso
2007 BMW M Coupe
EDIT: Thanks keith.
Antonio, got your posts back!!!!
Raxephon
elwesso wrote:EDIT: Thanks keith.
Thanks!
wirelessalpha
Car: 93 SR Vert, 96 318ti, 06 Altima
ICE ? I think it stands for "integrated Car Entertainment"...something like that. It has to do with having a stereo system....can someone confirm please?
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
AZhitman wrote:VLSD - Variable Limited Slip Differential
Greg, not that I am questioning your knowledge...well, yes I am.
But doesn't VLSD stand for Viscus Limited Slip Differential?
And HICAS is High Capacity Actively Controlled Suspension
Sil40_Mayhem
Car: 1995 Nissan 240SX 5spd
1992 Acura Integra LS
+1
Granted, it was only ECU/ECM and TCU/TCM, but what's the haps, Wes? Anyway, I'll add more:
EBFD - Electronic Brake Force Distribution (usually part of a stability control system)TC - Traction ControlECS - Electronic Stability ControlGVW - Gross Vehicle WeightECCS - Electronic-Conetrated Engine Control System
added- Wes
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
FICV- Fast Idle Control ValveCHTS- Cylinder Head Temperature sensorAFM- Air Flow MeterPTU- Power Transistor UnitFP- Fuel PumpFPCM- Fuel Pump Control ModuleFPR- Fuel PUmp Relay
added- Wes
elwesso
2007 BMW M Coupe
thanks guys, going great so far.... putting these in an excel document this weekend!!
elwesso
2007 BMW M Coupe
I added all these to a spreadsheet.... Looking great so far!!!! If I edited your post with a note at the bottom, i have added them to the glossary.
