fueler »
https://forums.nicoclub.com/fueler-u54519.html
Tue May 01, 2007 12:38 pm
What do you mean you have 2 relays? Basically, there should be a wire sticking out from your modified relay. This wire, when receives a 12v signal, allows the fog lights to turn on or off, depending on the switch. This is the same 12v signal that you want dead with the ignition off, so you don't kill the battery. I stuffed it under the actual prong of a neighboring relay, after finding that the ac relay had a prong which is hot with the car on and cold with the car off. I have no idea what the relay controls, as the air conditioning system works fine with this relay removed.
