Increasing clutch pedal pressure
trpower7
I recently had an OEM clutch installed in my S13, and after adjusting the front pedal height bolt, which did help to stiffen it somewhat, it is still remarkably soft. It holds just fine, no slipping, but engagement is somewhat imprecise and soft. I know that even an OEM clutch should be stiffer than this, is there another way to adjust I haven't tried yet???
WorkinDriver
Car: 240's
I know what u mean, I just had mine replaced but its soft in cold air, and gets stiff in warm air and then slips, What kinda fluid are you using. It takes DOT 3, but I put synthetic in because its a little thiner, it seemed to help my prob. It sound s like you could use a little thicker fluid.
