mig240sx »
https://forums.nicoclub.com/mig240sx-u59427.html
Sat Oct 13, 2007 8:29 am
It should hold up, but it won't last as long (depending how often you floor it). Like cnichols said, the axles will go first. I won't concern myself with how much hp the rear end will hold, the real question you should be asking is how much torque can it handle? Torque is what breaks stuff, not the hp (at least off the line and with good tires). If you were to use street tires and/or drag radials, your tires will give before your axles or rear end goes. But you want to run slicks!
Since you want your car to be a daily driver, I would just buy the upgraded rear end and axles so if it were to eventually go, you would have your car up and running fast (instead of having to find the parts later with no car).
I recommend, keep your torque under 400 and your hp under 500 and you should be ok. With a light car, you won't need that much torque or you will be spining like crazy when your not on slicks (daily driving). That's how I'm setting up my daily driving beast.
Modified by mig240sx at 11:37 AM 11/4/2007
