incorrect timing causing problems
scato
yesterday my bro decided it would be smart 2 remove my distrubuter from the engine. so after a couple hours we got the car from no where to tdc and got everything workin again. stated the car was running correct after some corrections. so i test drove and it was all good. i turn off the car. later i decide to go out. i get nowhere..... car wont start. and now i have no clue. so it sat last nite and i goto crank it 2day, and it fires right up, but it was idleing high then it would idle @750 then it jumped up to 1500revs and so i turned it off, and now i get nothing again. my dad said sounds like a rod, but is there anything else it could be? am i missing ne thing?
JeromeS13
Car: 2008 Subaru Impreza STI
Timing off, vacuum leak, etc.
-Jerome
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
yeah, get a timing light and check your timing again.
vancouverbc
Car: 1991 240sx
180fan
Car: 89 fastback
not to mention not putting "need help asap" in the thread title.
