blackmax23 »
https://forums.nicoclub.com/blackmax23-u66692.html
Wed Dec 26, 2007 10:56 am
Do you have larger than stock rims/tires? If you do, invest in $5.00 hub centric rings and take your rims/tires off and throw those rings on because the rims are made to fit a bigger hub, so if you don't have hub rings, you'll feel quite a shimmy. Now, if you have stock rims/tires, then yes it might be your engine mounts, but you'd see more shimmy under acceleration and not much driving down the highway at a constant speed. I would also check your bushings. I don't believe it's the tie rod because if you had tie rod problems, you could turn the wheel about a 1/4 turn right or left and the car will stay straight, it won't turn one way or the other and when you reach that point in the steering after 1/4 turn or so, the car will jump in that direction.
