INCONSISTENT TRANSMISSION FLUID LEVEL
SUB ZERO CAR FANATIC
Car: 1993 Infiniti Q45 ( SOLD)
1997 Cadillac Deville Concourse
1998 Cadillac Seville STS
2009 Infiniti QX56 LE
Well........ i went to check the fluid level aftercar had been sitting in below freezing weather for a couple of days, well when i pulled dipstick out of transmission fill tube, fluid overflowed from fill tube,so i sucked out enough fluid that fill tube was not full of fluid anymore, a couple days went by and i went out to check fluid level again, this time when i pulled it out it did not overflow but the transmission fill tube was full oftranny fluid again!! This is very confusing, there are no messages displayedabout transmission malfunction, engine light or nothing. The motor runs wellwith the exception that the idle flucuates up and down up and down.The trans mission seems to shift fine and smooth, i havent had car past 40mph since new motor and transmission install because i havent had it on the highway yet just around the block where i live. no plates or tags yet!where do you buy the BG 44 AT AND HOW MUCH IS IT? I pay $8 a quartfor mobil 1 synthetic here if thats any clue for price comparison. I know this topic has been ongoing for a while and i appreciate everyoneshelp and insight between us all here maybe someone has seen this problem before if not maybe we can figure it out to gether. Brian you stand correct about the output line on transmission my friend, thanks for your help, much appreciated!! help me lick this problem guys!! thanks again SUBZEROCARFANATIC
Sorry, wasnt trying to confuse anybody. I know im not the best typistor good at writing, but i thought it would be good enough for everyoneto at least understand what im trying to say! Once again someone hasplenty of smartass comments about something completely off subject,instead of trying to be helpful to someone asking for help you would ratherwaste your time criticising someone because they are not perfect!!What really pisses me off is it's not constructive criticism,your just boredwith nothing to do, and you obviously have no knowledge on the subjectso you must be a post queen! Go waste your time somewhere elselike general discussions instead of here on the Q45 forum where peoplecome for help and knowledge, not to waste time like im doing on a ***-holelike yourself. Maybe meth labs are your area of expertise since youseem to know so much on the matter, you shouldnt judge people you know nothing about BRIAN!!!
Modified by SUB ZERO CAR FANATIC at 12:14 PM 3/25/2008
Modified by SUB ZERO CAR FANATIC at 12:25 PM 3/25/2008
NightRiderQ45
Car: 1998 Infiniti Q45
SUB ZERO CAR FANATIC wrote:Hello everybody! I thought i had my transmission issue resolved, however..... thats not completely true! I got the transmission cooling linesall straightened out and on correctly. We thought the heat exchanger inletsand outlets in the radiator might be affecting the flow of transmission fluid, luckilythat wasnt true. I could blow through all 4 rubber lines connected to theradiator and air would exit out opposite end( if i blew in top right trannyline that goes in to radiator it would come out bottom right transmission line onradiator, if i blow in top left transmission line going to radiator it comes out bottom left transmission line on radiator) so in other words the heat exchangeris not plugged up so transmission fluid is flowing through cooler like it should. I disconnected both hard lines coming directly off transmission to check and see which line was the output line(which was the line coming outof the passenger side of the transmission) fluid was flowing good so i knowoutput is fine. Return line is fine and functioning properly as well, so this rules out transmission cooler not working, plugged input or output line fromtransmission is ruled out, transmission over filled is ruled out, so why is itwhen i check car after transmission is hot and car is idling in park fluid shows to be maybe.......1/2 quart low possibly 1 quart at very most, and the fluid finally quit boiling out when trying to check dipstick after car was turned offso i assumed problem solved. Well........ i went to check the fluid level aftercar had been sitting in below freezing weather for a couple of days, well when i pulled dipstick out of transmission fill tube, fluid overflowed from fill tube,so i sucked out enough fluid that fill tube was not full of fluid anymore, a couple days went by and i went out to check fluid level again, this time when i pulled it out it did not overflow but the transmission fill tube was full oftranny fluid again!! This is very confusing, there are no messages displayedabout transmission malfunction, engine light or nothing. The motor runs wellwith the exception that the idle flucuates up and down up and down.The trans mission seems to shift fine and smooth, i havent had car past 40mph since new motor and transmission install because i havent had it on the highway yet just around the block where i live. no plates or tags yet!where do you buy the BG 44 AT AND HOW MUCH IS IT? I pay $8 a quartfor mobil 1 synthetic here if thats any clue for price comparison. I know this topic has been ongoing for a while and i appreciate everyoneshelp and insight between us all here maybe someone has seen this problem before if not maybe we can figure it out to gether. Brian you stand correct about the output line on transmission my friend, thanks for your help, much appreciated!! help me lick this problem guys!! thanks again SUBZEROCARFANATIC
Trying to read this is very confusing and straining to the eyes...
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
What's a paragraph? Hell, what's a sentence?
Please edit for comprehension and legibility.
NightRiderQ45
maxnix wrote:What's a paragraph? Hell, what's a sentence?
Come on Sub Zero.... get it right. Maxnix, I thought I only felt like that
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
It's difficult trying to help someone whose post is incomprehensible and causes one a headache just to read it.
If posters want a wll considered answer, please construct a well constructed post with accurate information clearly discernible.
Ya think there might be a few meth labs up there?
NightRiderQ45
maxnix wrote:Ya think there might be a few meth labs up there?
!! My fellow engineers in the office here all just stared at me because I started laughing out loud!!
captainluigi
Car: 1996 q45t
Chris, tried your email. Undeliverable.
have possible help for your prob.
Email me
[email protected]
Capt my email is not working,thats why you cant send me a email.Im in the process of buying a new one mine is a intel pentium II,Its very outdated and slow. and i think im having software troublealso!! I cant send mail at all and i dont recieve it most of the time!!can you post it here.
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
Gee Whiz.
So much animosity.
Is traffic bad in Alaska? How much of a chance is there that you'll get in serious trouble for driving the Q around to test?
Just wondering.
captainluigi
Car: 1996 q45t
Call Brandon @ Born-Again Transmissions @ 907-458-7267.
Do not worry. He will not attempt to save your soul.
He will attempt to help you with your problem free of cost.
Tell him that crazy Fl. captain sent you.
Best of luck.
P.S. Please try to use paragraphs or at the least some spaces.
Haitian_King wrote:Gee Whiz.
So much animosity.
Just wondering.
Im more worried about some idiot sliding into me totaling my Qthan anything else,id rather wait until i have everything legal. Tags,plates,insurance,im inspection.
captainluigi wrote:Call Brandon @ Born-Again Transmissions @ 907-458-7267.
Best of luck.
I'll try!! How do you know about BORN AGAIN?
A good friend of mine name jason wilson used to work there,he was killed in a mva about 5 yrs. ago.
I know the owner, i believe his name is RICK, i met him through JASONwhen he was working there about 6 years ago,dont know if RICK still owns it or not!
The thought had crossed my mind about talking to them i just wasntsure how much knowledge they had on the Q45!
It's quiet different than most cars i've ever worked onand i have worked on cars off and onsince i was about 12 yrs. old.Most of my family on my DADS side have all been mechanics.
THANKS CAPT. , I APPRECIATE YOUR INPUTSUBZEROCARFANATIC
captainluigi
Car: 1996 q45t
Chris, sorry but i am unable to reveal my source of sources. Rest assured they will make every effort to be of help.
Thanks for the paragraphs. Much easier to read.
