Inconsistent A/F ratios at idle
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
After installing my M-300 i have noticed that sometimes my car idles at different AFRS. Sometimes it is in the 12-13 range sometimes 14-15 and sometimes in the 16-17 range. If I could get it to be consistent I could tune for it but I don't even know where to start? Any Ideas
fiznat
Car: Grown up :(
Your ECU will automatically richen up the fuel mixture if the engine (coolant) is cold- that could be making some of the difference.
Is your idle stable or does it wobble?
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
it stumbles a little bit at idle. The ECU would explain the rich side but what about the lean side? Thanks Fiz
fiznat
Car: Grown up :(
Its not running lean really. If the engine is warm and you're at a nice low idle 700ish, I've seen idle AFRs reaching 18:1 with no problems whatsoever.
Do you have a FSM? I would check to make sure your coolant temp sensor is in spec, along with your TPS and MAF. If those check out and your idle is still wobbly, look for a vaccum leak after the throttle body. Unmetered air getting into the intake charge would cause the symptoms you described as well.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
I'll check the coolant temp sensor tonight
nissanfanatic
Car: 1992 Nissan 240sx SE
A lot of times.. if you let the car sit for a minute, it levels out to 14:1-15:1...
