Projex240 »
https://forums.nicoclub.com/projex240-u4020.html
Sun Jun 27, 2004 8:32 am
For the longest time, I had a probelm with my clutch consistantly engageing at the top of the pedal throw(at full release only). I thought it was a hydraulic problem so I replaced the MC and the slave, bled it alot, then went driving. Same thing. So then I tried to adjust the redal rod, this helped a good bit, as it was then grabbing at about 1.5 to 2 inches of the floor board. But then a new problem started--the pedal would grab as it should when first cranked for the day, like in the morning. it would grab right of the floor board for about 10 miles worth of driving. Then, if stopped, it would start to grab about midway and get to about almost the top of the pedal throw(full release). If I pump the clutch a few times while in neutral--- rolling or whatever, then try to engage the clutch again, itll grab where its supposed to--right off the floor board. I begab to think it was the clutch disk itself--it was an act street disk--but it had about 70k on it, and it was time to replace it im usre. I put in a spec stg 3 4 puck sprung disk and a fidanze fly wheel. It grabbed pretty good at first, its kinda an on/off switch--which is cool with me--i like the engagement--but then it seems as though the clutch wants to start the same crap on me--its getting pretty aggrevating--and im thinking that theres air in the line or something, regargless of how much i bled it. It seems like the clutch, while not slipping at all--wants to enagage as though its kinda inconsistant. It grabs good, but not like the on/off switch its supposed to be.
Whats the best route for bleeding the clutch system?Also---what other problems could be? The cluch mc and slave are pretty new, the cltucha dn fly are new, and the pedal is adusted right(as far as I know)
-Josh
