ok hate to resseruct but i have searched a bunch of the sponsors and have found nothing for the ka24e in turns of upper engine components. basically my valve seals are leaking so i figured I might as well make it bullet proof when i rebuild it. so please if anybody knows of a website that would be great.hypertek_sideview wrote:are asking in regards to valve guides. solid rocker assembly, valve retainers, springs, valves and head studs??
if i remeber corectly..the headstuds are the same for bothe the ka24e and ka24de..its (10) 10mm. studs...springs..i have no clue about..but i do know that tome makes valve guides and seals..got mine from sportcompactwherhouse...they allso carry a line of pistons there rod and bearings...id sugest thou..before dumping 2k into a SOHC block..id at least upgrade to a DOHC..if i read ya correctly and your running a single cam...anyways..to each there own..and good luck...ps..Brian Crower makes great cams man.hybrid_flyer wrote:
