in need of some help
zcoffey
Car: 1992 240sx hatch
ok heres the thing what cam swap should i do if i want low end and mid range power? also what cars are those cams found in? and a quick rundown on how to install them? please
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Check out these threads....
Cams to get...zerothread?id=283375
Cam install...http://www.jimwolftechnology.c...E.PDF
I wouldnt suggest taking cams from other KA24de's unless you are looking for similar power. I would get the buddy club 264 cams, they seem to be making some decent all around power. Good luck and if you see the search button at the top. Search "ka24de cams" and you will get a lot of good info.
koukis4teen
Car: 1998 240sx LE
heres the jist but do your research and don't expect miracles. exhaust cam from s13(248 i think? i dunno look it up lol) and put it in the intake side and one of the s14 cams( they are both 232) and put it in the exhaust side
zcoffey
do i need to rotate either cams??
koukis4teen
Car: 1998 240sx LE
yeah the exhaust cam you put in the intake side rotate 4 teeth counter clokkwise.
