In need of s13 tech tip
EJL1985
Car: S13 240sx Red-top/ Toyota Solara
Hi readers, I'm having some trouble with my '90 240 front suspension. Trying to install kyb agx struts with eibach sportline springs. The issue Is compressing the suspension so I can line up the the lower mounting bolts. Using spring compressors I can line up and slide the bolts into place, however due to limited space I can not loosen the compressors. I've tried flipping the spring compressors up side down, no luck. Does anyone have a helpful tip to alight the holes to install the bolts? Help is appreciated.
