Well the sr20det swap is easy. Just drops in with the transmission bolted up and everything. Wiring isnt too difficult but if you are lazy there are a number of companies that will do it for you. Phase2 did a great job and even labeled all the plugs. But the swap will usually cost more than you think. there are many little things that you will want.
fuel pumpfuel filtergauges to monitor enginethe 90 cluster doesnt work if i remeber correctly ( tach at least )hope you got a cherry pickerfluidspeople say to use 91+ p/s lines, but we just redid the stock ones
I'm sure that i've forgot to list something but im really lazy. Also if you do decide to go SR, get your clip from a good source, if some of the parts are busted you dont wanna have to be spending extra to replace what should have worked in the first place.
If a couple of teenagers could swap it in a few days, im sure you could do it as well.
