evildky wrote:you need to fix the fuel issue right away, the injector O rings are a common issue and very laborious to replace but I'd recomend you contact your local z club (zcca.org) and found out who in your area specializes in Z32's, I'd never let a tire store do serious mechanical work on one fo these cars
and maybe yiu should just go to z clinc and let them have a look, sounds liek they'll have a much better idea of what they are looking at
Agreed. These cars are very complex and beyond what most places are capable of handling. If you are not going to do the work yourself, pay the premium and go to a Z specialist. It is worth the money. But, be warned, the Z32 is an expensive hobby. Even doing all my own work, I spend a ton of cash on this car. I simply would not be able to own it and maintain it properly if I had to pay for someone to work on it.
Start trying to do some of the things yourself. Look at the fuel leak for starters. If you open the hood and look on the drivers side wheel well, you will see a large canister (about 3.5 inches long and 3 inches in diameter), with a line coming in the rear and one running over to the motor. That is your fuel filter. Follow that line around the engine and tighten every clamp. Visual inspect the connections for wetness and smell. You may be surprised what you find out and possible fix.
