couldn't find much else so... here goes nothing.....S13DrIfTmEkAnIcS wrote:its been done but its a huge waste of time and money. its supposed to raise compression to 11:1. its a good set up but you will have to change timing covers, timing set up, oilpan, distributor, and a few other things. i'm doing a set up that i'm putting the single cam pistons in my dual cam block. its basicly a full rebuild just replacing the dual cam pistons with the singlecam pistons. its a whole lot easier and more affordable.
Here's the situation...
I recently picked up a dohc ka for free - just the price of gas to go get it blown with massive hole in the side of cylinder #1... The head is ok and so is the crank - don't ask me how.... Rod and piston have disintegrated and the oil pan was gone when I got the motor...
I currently have a set of eagle ESP h-beam forged rod's that are brand new in original box...
Here comes this topic into play....
I also have a sohc block that the head gasket blew and overheated warping the head gave ten bucks for it off my friend when he pulled it out of his car... took it to my local machine shop and had them check the deck and crank journals - for free... I know the guy really well...
All is within spec.... and ready to be thrown together... Just need's a crank - sold it a while back.... could possibly get it back tho if i can ever get ahold of the guy just sitting in his garage....
So my questions are: Has there been a write-up for this?
Is it truely possible?
I know I'll have to swap the timing chain cover's...Are the lower timing chain guides the same?
Which crank should I use in the sohc block or are they the same part#?
Will compression be the same as a dohc if I bore the block 20 over and use a set of cp forged piston's?
Second scenerio....
I have a dohc ka in my red s13 right now... I rebuilt it not to long ago and have been busy with other thing's and selling parts to mess with it very much.
The motor has NEVER been fired up and is still at Top dead center....The head has been resurfaced hot-tanked cam journals were polished The block is completely stock... didn't have enough cash nor the time and right tools to delve into rebuilding the bottom end when I was working on it...
Since then I have purchased the eagle rod's and I have the cash to buy forged piston's... Which I'd like to use with my head that's had work done to it... I have ARP head stud's and a Cometic MLS head gasket on it right now... I'm not worried about getting it running the way it is even tho everything is hooked up and ready to rock and roll....
Now your prob askin why not..... since it's all put together right? NO.... I just sold my maroon 240 and I wasn't about to let my full 5 lug swap and 300zx brakes leave with it... So I pulled the suspension and brakes out from under the red 240 and slapped it onto the maroon one so the guy could have a stock rusted rolling chassi....
Red 240's still on blocks right now I know its a lil red-neck right? lol I don't care...
I just bought a set of tein inner and outter tie-rod's, front and rear sway bars and sway bar links, adjustable rear upper control arms, adjustable tension rod's, a set of 20mm and a set of 25mm wheel spacers to throw on it... It's snowing out and I don't have a garage let me remind you that the car is yes... you got it.... On BLOCKS with no shock's no control arm's no wheels no hub's.... NOTHING......................!
Soooooo....... this means all this work has to be done in either the cold a$s weather or wait till spring and knowing me.... I'll prob throw on the carhart and go to work in this shrit!
Also... I bought a very clean rolling chassi for dirt that I couldn't pass up! basically sold my rusted maroon one straight up for a non rusted one It's a 91 and I need a motor for it to have a daily driver. I have a transmission and all the dohc parts in the car still
See where I'm goin yet....?
I def need some Nico help guy's Let's get this all figured out for others that find themselves in this kinda scenario... And lets get me out of a ford race-cort station wagon daily driver!
Modified by cmoody2006 at 5:53 AM 12/13/2008
