OGtrippleOG wrote:WOW ! do u by chance work @ phantom auto works?
Nope, I only wrench on my own car now. But I am full of shi...advice.
I would find a general mechanic that you know is good from personal reviews (my Mom goes to a guy who is excellent for routine stuff) and have them change the coolant, oil & filter, brake fluid, power steering fluid, diff fluid and transmission fluid (auto) or gear oil (manual).
Then a tune up - radiator hoses, belts, spark plugs, cap & rotor, plug wires, air filter, fuel filter. Plus an engine inspection to see if any vacuum line problems or exhaust/gasket/oil leaks are seen.
Coilovers are for 2 things - lower the car so it looks better and replace usually blown out stock struts & shocks. They are expensive ($500 used / ebay - $1200 for brand names) but don't bother with springs & shocks 'cause they will never get low enough to look good IMHO.
Post up your questions here, then you get more than one opinion.
Also search on Facebook groups for "NY NJ CT S13 240SX Silvia" and you will find a lot of good local groups and events.
